1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: VxWorks 6.7, MV5500
Date: Fri, 09 Jul 2010 11:23:18 -0400
Hello:
On 7/9/10 11:03 , "Andrew Johnson" <[email protected]> wrote:
> I would be very interested to know whether the libCom/test/epicsExceptionTest
> program detects this.
Yes, epicsExceptionTest fails, so it's a good test!
epicsTimeTest also fails on some exception.
Exeptions in general don't seem to function with our combination of vxWorks
6.7 & MV5500.
Other tests look OK.
> IIRC Ron Sluiter discovered a similar problem with C++ exceptions on the
> target solaris-x86_64-gnu which was detected by that test routine; I'm
> attributing that failure to gcc
I agree and would like to hear from other people who use VxWorks 6.7 with
the gnu compiler (WindRiver 4.1.2), maybe even on an MV5500 about their
vxWorks kernel settings and compiler flags.
Kay
Re: VxWorks 6.7, MV5500 Andrew Johnson
Re: VxWorks 6.7, MV5500 Re: EPICS R3.14.11, sequencer 2.0.12 crash on device support write error Andrew Johnson
Prev: Re: linking to shared objects user libraries J. Lewis Muir
Next: Re: iocStats Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: VxWorks 6.7, MV5500 Re: EPICS R3.14.11, sequencer 2.0.12 crash on device support write error Andrew Johnson
Next: Re: VxWorks 6.7, MV5500 Andrew Johnson
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
