You don’t want to downgrade to 3.80.
You need 3.81, but there were several versions on Cygwin that were
labelled 3.81, at least one of which did not work.
You can get a gzipped file with the
version I am using at
http://cars.uchicago.edu/software/pub/make.gz
Hi all,
I have build EPICS Base 3.14.9 on a PC with Windows
XP, Microsoft Visual C++ 2008 Express Edition, cygwin 1.7.5-1, Active Perl 5.10.1
and the GNU make 3.81 that comes in the cygwin packet.
I’m trying to create the Example IOC
Application from the EPICS Application Developer’s Guide with command
window, but when I build it with make, I have the following Error:
*** multiple target patterns. Stop.
I have read in the mailing list that could be because
the GNU make 3.81 doesn’t recognize DOS paths and I want to downgrade
cygwin’s GNU make to 3.80. How can I do that? I have downloaded the tar
file and now?
Maybe someone have the same Error, but has used
another solution.
Thanks in advance,
Gorka
