1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.?
To: "Gary V. Vaughan" <[email protected]>, <[email protected]>
Date: Thu, 5 Aug 2010 14:47:14 -0400
Hello Gary,
The problem is larger than just installing files into standard
locations.  The real difficulty is in patching the EPICS build system to
use a different layout.
When I was considering how to package EPICS for Debian Linux I made the
decision to keep the current layout, but to move the root
'/usr/epics/base', and I am considering changing this to
'/usr/lib/epics' to better follow Debian's rules regarding file system
layout.
Is there a reason you want to rearrange things (aside from the
strangeness of the current arrangement)?
As for installing outside the build directory try:
$ make
$ make INSTALL_LOCATION=/usr/local/epics
Be aware that by default installed binaries are linked with -rpath.
Michael Davidsaver
NSLS2 Controls Group
Brookhaven National Lab
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Gary V. Vaughan
> Sent: Thursday, August 05, 2010 2:14 PM
> To: [email protected]
> Subject: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib
etc.?
> Hi,
> I am in the process of trying to package EPICS base 3.14.11 into
> native package format on several commercial UNICES, but I can't
> find a nice way to have it install into a standard tree:
>   $INSTALL_PREFIX/
>     +-- bin/
>     |    '-- {binaries and scripts go here}
>     +-- db/
>     |    `-- softIocExit.db
>     +-- dbd/
>     |    `-- {dbd files}
>     +-- doc/
>     |    '-- html/
>     |         `-- {html documentation}
>     +-- include/
>     |    `-- {C and C++ header files}
>     +-- lib/
>     |    +-- {compiled libraries}
>     |    `-- perl-5.8.8/
>     |         `-- {perl modules}
>     `-- templates/
>          `-- {template files}
> If I change INSTALL_LOCATION to be anything other than $(TOP)
> then make fails to find any sources to link, and there don't
> appear to be any installation rules to relink the libraries
> and binaries at install time -- nearly all other programs I've
> packaged provide a 'make install' rule for this purpose.
> I've got a kludgy workaround that finds lines in the build.log
> file beginning 'g++ -o', and calls the installed libtool script
> to relink targets that match into the install tree structure above
> without leaving references to directories or libraries in the build
> tree in RPATH entries.
> Is there a way to install a runtime EPICS base into the root
> directory using the existing build system?
> Thanks in advance for your help!
> Cheers,
> Gary V. Vaughan ([email protected])
How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Gary V. Vaughan
Prev: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Ralph Lange
Next: VxWorks and Radius Authentication Gary Carr
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Gary V. Vaughan
Next: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Andrew Johnson
