1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Runtime Input Question
To: [email protected]
Date: Tue, 17 Aug 2010 16:13:16 -0700
Hey again,
I'm pretty close to having my magnet ramp code implemented but I need to know how to have a record access a user defined input during run time. For instance I want to turn a dial in MEDM to set the ramp point of the magnet. So far I've implemented a database as follows:
#Calc Coil Current
record(calc, "Current:Coil") {
  field(DESC, "Coil Current")
  field(SCAN, "Passive")
  field(MDEL, ".1")
  field(ADEL, ".1")
  field(CALC, "LA + A*1/1200")
  field(INPA, "$(MUX):VOLT:Chan204.VAL  PP MS")
  field(PINI, "NO")
  field(EGU, "A")
  field(SDIS, "0")
#Calc output and write to AG3631 Voltage programmer
record(calcout, "Voltage:Output") {
  field(DESC, "Output Voltage")
  field(SCAN, "1 second")
  field(CALC, "Voltage:Output.VAL + (B - A)*.5/1")
  field(INPA, "Current:Coil.VAL  PP MS")
  field(INPB, "Runtime Input")  # How do I link to user input?
  field(OOPT, "On Change")
  field(DOPT, "CALC")
  field(DTYP, "AG3631")
  field(OUT, "#L$(L) $(A) @0")
  field(PINI, "NO")
  field(EGU, "V")
  field(SDIS, "0")
How do I set the INPB to link to a runtime input? I've seen an example where a "dummy" AI record is linked, but I'm not sure if there is a better way. I would also like to put some protection logic in place. For instance, I would like to calculate a V_min and V_max (functions of Current:Coil) that Voltage:Output must be between in order for the OUT link to be processed. Are there any examples of how to implement this? The documentation doesn't really have any. Thanks again for your help.
Andrew
Re: Runtime Input Question Tim Mooney
Prev: Re: Asyn and I/O intr scanning Eric Norum
Next: Re: Runtime Input Question Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
