1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA gateway dies without error message
To: EPICS <[email protected]>
Date: Thu, 19 Aug 2010 15:52:28 +0200
Hi all,
Since upgrading the EPICS base version of the caGateways to 3.14.11, the gateway dies from time to time for no obvious reason. It does not write any log message when it dies (as it would do in a clean shutdown, in case of a signal or when any strange CA event happens.) It also does not write anything to stderr. I cannot remember that I have seen this type of fault with 3.13.8.
Any idea?
Dirk
Re: CA gateway dies without error message Andrew Johnson
RE: CA gateway dies without error message Jeff Hill
Prev: Re: Asyn and I/O intr scanning Hinko Kocevar
Next: RE: hex stream processing with StreamDevice? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: synApps/vme-2-7/vmeApp/src for RTEMS (using EPICS libCom/osi Library) required Heinz Junkes
Next: Re: CA gateway dies without error message Andrew Johnson
