Hi Dirk,
On Thursday 19 August 2010 08:52:28 Dirk Zimoch wrote:
> Since upgrading the EPICS base version of the caGateways to 3.14.11, the
> gateway dies from time to time for no obvious reason. It does not write
> any log message when it dies (as it would do in a clean shutdown, in
> case of a signal or when any strange CA event happens.) It also does not
> write anything to stderr. I cannot remember that I have seen this type
> of fault with 3.13.8.
Can you try running the gateway process under gdb, to see if that catches anything when it dies?
Our ctlapps4l gateway built with 3.14.11 on Linux has apparently been running continuously since March 18th. We don't normally allow puts through that gateway though, so you could be exercising parts of the code that we don't use here.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Re: CA gateway dies without error message Martin L. Smith
- Re: CA gateway dies without error message Steven M. Hartman
- CA gateway dies without error message Dirk Zimoch
Re: hex stream processing with StreamDevice? Dirk Zimoch
<2010>
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
