1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: CA gateway dies without error message
Cc: [email protected]
Date: Thu, 19 Aug 2010 10:07:29 -0500
Hi Andrew and Dirk,
We do allow puts through the PV gateways on Linux-x86 (ctlapps4l),
Solaris-x86 (User gateways), and Solaris-sparc (rhea) which are all
built against EPICS 3.14.11
I have had some of them running since March, April, and June since we
have about 40 gateways. I have not seen any widespread problems with them.
Marty
Andrew Johnson wrote:
Hi Dirk,
On Thursday 19 August 2010 08:52:28 Dirk Zimoch wrote: > > Since upgrading the EPICS base version of the caGateways to 3.14.11, the > gateway dies from time to time for no obvious reason. It does not write > any log message when it dies (as it would do in a clean shutdown, in > case of a signal or when any strange CA event happens.) It also does not > write anything to stderr. I cannot remember that I have seen this type > of fault with 3.13.8.
Can you try running the gateway process under gdb, to see if that catches anything when it dies?
Our ctlapps4l gateway built with 3.14.11 on Linux has apparently been running continuously since March 18th. We don't normally allow puts through that gateway though, so you could be exercising parts of the code that we don't use here.
- Andrew -- The best FOSS code is written to be read by other humans -- Harald Welte
Re: CA gateway dies without error message Ralph Lange
CA gateway dies without error message Dirk Zimoch
Re: CA gateway dies without error message Andrew Johnson
Prev: Re: CA gateway dies without error message Andrew Johnson
Next: Re: hex stream processing with StreamDevice? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: CA gateway dies without error message Ralph Lange
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
