1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Small patch for asynMask bitmask values
To: tech-talk <[email protected]>, Mark Rivers <[email protected]>
Date: Fri, 20 Aug 2010 11:31:19 +1000
Hi everyone,
I have a trivial patch for asyn 4-13-1, I thought I'd send it to the
list for comment as well as to Mark directly.
I've been setting up a lot single binary inputs and outputs, so making
masks like this:
field(OUT,"@asynMask( xvme260-1 0 0x4000 )")
and I was thinking it'd be nice to be able to use a 1<<x or a BITx
notation for single bit values. Most of the cards I'm using have a
direct relationship between bit number and channel number, and it's nice
to save the reader from having to do it in their head.
So my tiny patch just adds support for optionally specifying single bit
values, in masks, as follows:
field(OUT,"@asynMask( xvme260-1 0 bit14 )")
The patch adds a mention in the documentation as well, although I
haven't added any test cases.
Hope this is of some use,
- Angus
Index: documentation/asynDriver.html
--- documentation/asynDriver.html	(revision 16)
+++ documentation/asynDriver.html	(working copy)
@@ -3933,7 +3933,9 @@
     interface asynUInt32Digital. The INP or OUT field must define asynMask. The mask
     specified in the argument to asynMask is used in the calls to asynUInt32Digital
     methods. In addition it is used to set the mask fields in bi and bo records and
-    the mask and shft fields in mbbi, mbbo, mbbiDirect, and mbboDirect records.</p>
+    the mask and shft fields in mbbi, mbbo, mbbiDirect, and mbboDirect records. Mask
+    values can be specified as decimal or hexadecimal integers, or a single bit can be
+    identified using the notation 'bitX' (equivalent to the C expression 1<<X.)</p>
   <ul>
     <li>biRecord
       <p>
@@ -3992,7 +3994,7 @@
     Binary Output Example Record</p>
   <pre>record(bo,"boUInt32Bit2") {
     field(DTYP,"asynUInt32Digital")
-    field(OUT,"@asynMask( $(port) , 0, 0x4 , 1.0) ")
+    field(OUT,"@asynMask( $(port) , 0, bit2 , 1.0) ")
     field(ZNAM,"zero")
     field(ONAM,"one")
 }</pre>
Index: asyn/devEpics/asynEpicsUtils.c
--- asyn/devEpics/asynEpicsUtils.c	(revision 16)
+++ asyn/devEpics/asynEpicsUtils.c	(working copy)
@@ -155,7 +155,21 @@
     return(asynSuccess);
+// Scan a value for a bitmask, which can be either a number suitable for
+// strtoul or a value 'bitX' for X in the range 0-31
+epicsUInt32 scanMaskValue(const char *start, char **end)
+	if(strncmp(start, "bit", 3) == 0) {
+		epicsUInt32 bitValue = strtoul(start+3,end,0);
+		if(bitValue || !errno)
+			return 1<<bitValue;
+		else
+			return 0;
+	return strtoul(start,end,0);
 static asynStatus parseLinkMask(asynUser *pasynUser, DBLINK *plink,
                    char **port, int *addr, epicsUInt32 *mask,char **userParam)
@@ -196,7 +210,7 @@
     pnext = skipWhite(pnext,1);
     if(*pnext==0 || *pnext==')') goto error;
     errno = 0;
-    *mask = strtoul(pnext,&endp,0);
+    *mask = scanMaskValue(pnext, &endp);
     if(errno) goto error;
     /*next is timeout*/
     pnext = endp;
Re: Small patch for asynMask bitmask values Angus Gratton
Re: Small patch for asynMask bitmask values Eric Norum
Prev: Re: Asyn and I/O intr scanning Eric Norum
Next: Re: Small patch for asynMask bitmask values Angus Gratton
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: agenda for the October meeting is updated (you may be scheduled to give a ttalk ; ) ) Dalesio, Leo
