What low-level driver are you using? i.e. what drvAsyn.......Configure command are you using to create the port in question?
On Aug 19, 2010, at 4:01 AM, Hinko Kocevar wrote:
> Hi Eric,
> On 08/17/10 17:44, Eric Norum wrote:
>> Have a look at the 'SRQ Processing' section of the devGpib documentation (<asyn>/documentation/devGpib.pdf). The command table type element should be GPIBREADW (or one of the other GPIBxxxxxxW values) which waits for the device to issue a SRQ then performs the read (or write) operation.
>> You do not have to use get_ioint_info yourself -- the devGpib code handles this.
> I've tried using
> {&DSET_SI, GPIBREADW, IB_Q_HIGH, "VOL:N5V?", "VOL:N5V %s\r\nOK", 0, 80,
> NULL, 0, 0, NULL, NULL, NULL},
> But the IOC says:
> 2010/08/19 12:39:19.606 FOO:BAR:VOL:N5V parm 4 gpibCmd.type requires
> asynGpib but it is not implemented by port driver
> PV: FOO:BAR:VOL:N5V scanAdd: I/O Intr not valid (no get_ioint_info)
> Do I need to add/change anything else?
> Thank you!
> Hinko
> Hinko Kocevar
> Technical support software engineer
> Instrumentation Technologies d.d.
> Velika pot 22, SI-5250 Solkan - Slovenia
> T:+386 5 3352600, F:+386 5 3352601
> mailto: [email protected]
> http://www.i-tech.si - When your users demand stability
> The information transmitted is intended solely for the addressee and may
> contain confidential and/or privileged information. Any review, retention,
> disclosure or other use by persons other than the intended recipient is
> prohibited. If you received this in error, please notify the sender and
> delete all copies.
Eric Norum
[email protected]
- Re: Asyn and I/O intr scanning Hinko Kocevar
- Asyn and I/O intr scanning Hinko Kocevar
- Re: Asyn and I/O intr scanning Eric Norum
RE: CA gateway dies without error message Jeff Hill
Small patch for asynMask bitmask values Angus Gratton
<2010>
<2010>
