1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Small patch for asynMask bitmask values
To: Angus Gratton <[email protected]>
Date: Thu, 19 Aug 2010 21:03:41 -0700
On Aug 19, 2010, at 8:38 PM, Angus Gratton wrote:
> Hi Eric,
> On Thu, 2010-08-19 at 19:13 -0700, Eric Norum wrote:
>> The 1<<N form seems reasonable, but I'm not 100% that the bitXX names are a good idea.   My concern stems from the fact that some architectures number bits from the right (which is what I presume this patch does) while others number them from the left.  Thus 'bit14' is somewhat ambiguous.
> That seems fair enough. I hadn't considered different bit numbering
> conventions. FWIW, the documentation section describes 'bitX' as
> equivalent to '1<<X', but I can still see your point.
> I have no objection to swapping the string "bit" for "1<<" in the patch.
> The reason why I didn't go with '1<<' up front is that this implies
> there may be a more complete set of expressions available to the user.
> Which could also be nice to have, but I think would require a more
> complex parser for @asynMask fields. Unless there's one elsewhere in
> EPICS (CALC?) that could readily be plugged in?
Sure.
Have a look at 'postfix()' and 'calcPerform()' in the appDevGuide.
Eric Norum
[email protected]
Re: Small patch for asynMask bitmask values Angus Gratton
Re: Small patch for asynMask bitmask values Eric Norum
Prev: Re: Small patch for asynMask bitmask values Angus Gratton
Next: procServ dies quietly when log file > 2G Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Small patch for asynMask bitmask values Angus Gratton
