Hi Ben,
On Monday 23 August 2010 07:27:03 Benjamin Franksen wrote:
> Sorry for replying to myself, but I found that the restriction that global
> substitution sets must precede file substitution sets is too, well,
> restrictive. In fact, I found a place where we use the /dev/null trick
> twice in two separate locations in the same substitution files.
> I have attached a new version of msi.c that allows mixing file and global
> sections. The semantics is that definitions inside a global section are
> valid from the point of definition to the rest of the file, except where
> overwritten by other global definitions or shadowed by local ones (in file
> sections).
Without actually delving into your msi.c code, I'd like to agree on a formal
grammar for the substitutions file. The dbLoadTemplate code currently
implements some extra features that are not documented, which I eventually
want to remove. I'm adding a warning message if someone uses them, and will
delete them from the 3.15 tree.
Having looked through the Yacc grammar for dbLoadTemplate I should point out
that it doesn't currently support empty patterns or substitutions. With the
addition of the global variables I think it makes sense to allow this:
file xyz {}
but I don't see why you'd need to be able to write either of these as well:
file xyz {{}}
file xyz { pattern {} {} }
Here's what I think the syntax should look like with "global" added, expressed
in EBNF:
substitution-file ::= ( global-definitions* template-substitutions+ )+
global-definitions ::= 'global' '{' variable-definitions '}'
variable-definitions ::= variable-definition ( ',' variable-definition )*
variable-definition ::= variable-name '=' value
template-substitutions ::= 'file' file-name '{' substitutions? '}'
substitutions ::= variable-substitutions | pattern-substitutions
variable-substitutions ::= '{' variable-definitions '}'
pattern-substitutions ::= 'pattern' '{' pattern-names '}' pattern-definitions
pattern-names ::= variable-name ( ',' variable-name )*
pattern-definitions ::= ( '{' pattern-values '}' )+
pattern-values ::= value ( ',' value )*
variable-name ::= variable-name-char+
file-name ::= file-name-char+ | double-quoted-string | single-quoted-string
value ::= value-char+ | double-quoted-string | single-quoted-string
double-quoted-string ::= '"' (double-quoted-char | escaped-char)* '"'
single-quoted-string ::= "'" (single-quoted-char | escaped-char)* "'"
double-quoted-char ::= [^"\]
single-quoted-char ::= [^'\]
escaped-char ::= '\' .
Currently dbLoadTemplate_lex.l defines the remaining terminals to be
variable-name-char ::= value-char
file-name-char ::= value-char
value-char ::= [a-zA-Z0-9_+:./\<>;[] | '-' | ']'
I would prefer something like these instead
variable-name-char ::= [a-zA-Z0-9_]
file-name-char ::= [a-zA-Z0-9_+:./\] | '-'
but such a change might break existing substitutions files.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Re: msi again Benjamin Franksen
- msi again Benjamin Franksen
Re: edm meter Andrew Johnson
GNU make 3.82 problem Allison, Stephanie
<2010>
<2010>
