FWIW, I was able to build EPICS R3.14.11 for RTEMS-mvme2100, RTEMS-mvme3100, RTEMS-uC5282 and darwin-x86 using GNU make 3.8.2.
On Aug 23, 2010, at 4:08 PM, Allison, Stephanie wrote:
> Hello,
> Has anybody built epics 3.14.11 using GNU make 3.82? I had to upgrade my gnu make and got 3.82 but then had problems with the EPICS base build where it tried to install an object library as a shareable library (on both solaris-sparc-gnu and linux-x86). I went back and got 3.81 instead - it works fine and I'll stick with it. I see that 3.82 is a very recent release (July 28, 2010). The software requirements for 3.14.11 say GNU make "3.81 or higher" so perhaps I'm doing something wrong.
> Thank you,
> Stephanie Allison
> [email protected]
Eric Norum
[email protected]
- GNU make 3.82 problem Allison, Stephanie
Re: msi again Benjamin Franksen
Re: error while loading shared library libstdc++.so.5:ARM based SBC Andrew Johnson
<2010>
error while loading shared library libstdc++.so.5:ARM based SBC tanushyam bhattacharjee
<2010>
