1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: error while loading shared library libstdc++.so.5:ARM based SBC
To: [email protected]
Date: Tue, 24 Aug 2010 12:17:04 -0500
On Tuesday 24 August 2010 00:07:33 tanushyam bhattacharjee wrote:
> I have cross compiled the vlinac application for an arm
> based system running debian and build the application with latest  g++
> runtime library,however,when I am trying to run the application the
> following error is coming
> Please give some clue to fix the problem.
This is probably not specifically an EPICS issue, it looks more likely that
you have some incompatibility between your cross-build environment for C++ and
the SBC linux installation you're trying to use.
Some clues to look for:  Does the SBC actually have a copy of libstdc++.so.5?
Is it the same as the one that your cross-gcc linked the vlinac against?  If
you run ldd on the linac binary (on the ARM system), does it show that as a
missing library?
You might need to build EPICS Base and the IOC as purely static binaries with
no shared libraries, which you would do by creating a file in base called
configure/os/CONFIG_SITE.Common.linux-arm file which contains the lines
    STATIC_BUILD=YES
    SHARED_LIBRARIES=NO
Then you have to rebuild base by typing 'make rebuild' in the top directory of
your base installation, and rebuild the vlinac application similarly.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
error while loading shared library libstdc++.so.5:ARM based SBC tanushyam bhattacharjee
Prev: Re: GNU make 3.82 problem Eric Norum
Next: agenda - registration Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: error while loading shared library libstdc++.so.5:ARM based SBC tanushyam bhattacharjee
