As I discovered today, msi does not handle scoping as I thought it would
(and think it should). What msi (both msi-1.5 and my extended version) does
is to open a scope for each
file <filename> { }
block. But *not* for each instance inside such a block, i.e. in
file xyz {
{ X=1, Y=a }
{ X=2 }
in the second substitution instance Y=a is still defined.
This is easily fixed by moving the calls to macPushScope and macPopScope
inside the inner while loop. The following patch is relative to my latest
version:
diff -rN -u old-msi/msi.c new-msi/msi.c
--- old-msi/msi.c 2010-09-06 13:53:50.687470977 +0200
+++ new-msi/msi.c 2010-09-06 13:53:50.687470977 +0200
@@ -125,12 +125,12 @@
fprintf(stderr,"no template file\n");
usageExit();
- if (optScoped) macPushScope(macPvt);
while((pval = substituteGetReplacements(substitutePvt))){
+ if (optScoped) macPushScope(macPvt);
addMacroReplacements(macPvt,pval);
makeSubstitutions(inputPvt,macPvt,filename);
+ if (optScoped) macPopScope(macPvt);
- if (optScoped) macPopScope(macPvt);
} while (isGlobal || isFile);
substituteDestruct(substitutePvt);
while this one is relative to msi-1.5:
diff -rN -u old-1-5/msi.c new-1-5/msi.c
--- old-1-5/msi.c 2010-09-06 13:59:11.819132417 +0200
+++ new-1-5/msi.c 2010-09-06 13:59:11.827129619 +0200
@@ -113,12 +113,12 @@
usageExit();
- macPushScope(macPvt);
+ macPushScope(macPvt);
+ macPopScope(macPvt);
- macPopScope(macPvt);
Cheers
Ben
Build IOC linking external *.lib file failed zhangning2095
RE: Camera Link drivers for areaDetector? fajin.yuan
<2010>
RE: Build IOC linking external *.lib file failed Mark Rivers
Examples of synApps scaler record using asyn port driver Angus Gratton
<2010>
