1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Testing the new DBE property in EPICS R3-14-11
To: [email protected]
Date: Thu, 16 Sep 2010 18:34:47 +0200
On Donnerstag, 16. September 2010, Ralph Lange wrote:
> On 12.09.2010 10:23, Ben Franksen wrote:
> > On Sonntag, 12. September 2010, Xu, Chengcheng wrote:
> >> I am trying to test out the EPICS record's new DBE property.
> > You mean the new CA event type called DBE_PROPERTY?
> > To summarize: this nice new feature is not yet fully implemented
> > for all record types; also, camonitor misses an option to specify
> > the request type to make this useful. I tried to add it but it
> > doesn't work.
> Are you sure?
>  > ./bin/linux-x86/camonitor -h
>      Usage: camonitor [options] <PV name> ...
>        -h: Help: Print this message
>      Channel Access options:
>        -w <sec>:  Wait time, specifies CA timeout, default is
> 1.000000 second(s)
>        -m <mask>: Specify CA event mask to use, with <mask> being any
> combination of
>                   'v' (value), 'a' (alarm), 'l' (log/archive), 'p'
> (property). Default: va
>        -p <prio>: CA priority (0-99, default 0=lowest)
Sorry, my wording was not clear enough. Sure, camonitor has the -mp
switch but not -d<dbrtype> (as you acknowledge below). This is what I
meant. I was trying to add the -d option (to camonitor.pl) and
initially had some problems, but solved them. See my follow-up message
with a successfully hacked camonitor.pl.
> > Looking at 'camonitor -h' I see no option for specifying the DBR
> > type, so it seems that --apart from timestamp and status/severity--
> > properties are not supported yet.
> Correct.
> The camonitor tool is aimed at looking at the timestamped values of
> many PVs over time. To keep the output readable, it follows the rule
> "one line per update".
> To caget that rule does not apply, so it does support all available
> data types, producing a multi-line output for any of the complex
> types.
> I would think that camonitor for the complex structures would yield a
> hard to read, if not unusable output.
> Of course: If you have a valid use case, please file a bug report
> explaining your case and including ideas how the camonitor output
> should look like for the complex types. I will seriously consider it,
> that's for sure.
(1) The OP asked for it.
(2) What use is 'camonitor -mp' if I can't see the properties?
(3) I don't think it is hard to read. Try my hacked version of
    camonitor.pl, I use the same format (in fact the same code) as
    caget.pl. It's a bit bulky but note that properties typically don't
    change as frequently as the value.
On Donnerstag, 16. September 2010, Andrew Johnson wrote:
> We could provide an option to output the complex structures using
> JSON,
What is the problem with using the same format as caget(.pl) uses?
> Having created the above example I realize one problem with the
> DBR_CTRL_xxx types is that they don't include a time-stamp, so
> they're not very good for monitoring values that change over time.
It is still useful. Most times I use camonitor I don't even look once at
the timestamps. We can also use client-side timestamps.
Cheers
Ben
Re: Testing the new DBE property in EPICS R3-14-11 Ben Franksen
Testing the new DBE property in EPICS R3-14-11 Xu, Chengcheng
Re: Testing the new DBE property in EPICS R3-14-11 Ralph Lange
Prev: Re: Testing the new DBE property in EPICS R3-14-11 Andrew Johnson
Next: RE: Stream Device With Parameters Gorka Ronda
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Testing the new DBE property in EPICS R3-14-11 Ben Franksen
ANJ, 16 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
