1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Testing the new DBE property in EPICS R3-14-11
To: [email protected]
Date: Thu, 16 Sep 2010 18:44:10 +0200
On Donnerstag, 16. September 2010, Ben Franksen wrote:
> On Donnerstag, 16. September 2010, Ralph Lange wrote:
> > I would think that camonitor for the complex structures would yield
> > a hard to read, if not unusable output.
> > Of course: If you have a valid use case, please file a bug report
> > explaining your case and including ideas how the camonitor output
> > should look like for the complex types. I will seriously consider
> > it, that's for sure.
> (1) The OP asked for it.
> (2) What use is 'camonitor -mp' if I can't see the properties?
> (3) I don't think it is hard to read. Try my hacked version of
>     camonitor.pl, I use the same format (in fact the same code) as
>     caget.pl. It's a bit bulky but note that properties typically
> don't change as frequently as the value.
> On Donnerstag, 16. September 2010, Andrew Johnson wrote:
> > We could provide an option to output the complex structures using
> > JSON,
> What is the problem with using the same format as caget(.pl) uses?
> > Having created the above example I realize one problem with the
> > DBR_CTRL_xxx types is that they don't include a time-stamp, so
> > they're not very good for monitoring values that change over time.
> It is still useful. Most times I use camonitor I don't even look once
> at the timestamps. We can also use client-side timestamps.
Another idea for increasing usability: Forget about DBR_XXX in the user
interface. Instead, let them specify a set of properties and display
just those, using whatever DBR type is appropriate (i.e. a superset).
If there is none (e.g. the user requests "timestamp+display_limits") we
could (a) give up and tell the user why, or (b) set up two monitors,
one with DBR_TIME_XXX and one with DBR_GR_XXX, then correlate the
events and merge them.
Cheers
Ben
"Never confuse what is natural with what is habitual."
                                                 -- Mahatma Gandhi
Re: Testing the new DBE property in EPICS R3-14-11 Ralph Lange
Testing the new DBE property in EPICS R3-14-11 Xu, Chengcheng
Re: Testing the new DBE property in EPICS R3-14-11 Ben Franksen
Prev: RE: Stream Device With Parameters Gorka Ronda
Next: RE: Stream Device With Parameters Gorka Ronda
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Testing the new DBE property in EPICS R3-14-11 Ben Franksen
Next: Re: Testing the new DBE property in EPICS R3-14-11 Ralph Lange
ANJ, 16 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
