1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Configuring an IOC to -not- build for host arch
Date: Mon, 20 Sep 2010 14:59:47 +1000
On Mon, 2010-09-20 at 14:31 +1000, Angus Gratton wrote:
> On Sun, 2010-09-19 at 22:44 -0500, Mark Rivers wrote:
> > I would suggest doing this in your IOC and support library Makefiles, not globally.
> > For example, this is my Makefile for a library for VME/Industry Pack hardware.
> > LIBRARY_IOC_vxWorks += ip330
> > LIBRARY_IOC_RTEMS   += ip330
> Perfect, thank you Mark. It hadn't dawned on me that all those Makefile
> values could be made OS-specific.
Of course, it would help if I actually tested things before replying to
emails! The _LIBS_RTEMS lines I had posted do nothing, it does need to
be as shown by you above.
Or alternatively PROD_IOC_RTEMS = myAppName works, as suggested by
Bruce, and that's what I'm using for now. We have a very simple build
environment so far, I'm sure it will scale up in the future.
- Angus
Configuring an IOC to -not- build for host arch Angus Gratton
RE: Configuring an IOC to -not- build for host arch Mark Rivers
RE: Configuring an IOC to -not- build for host arch Angus Gratton
Prev: RE: o.c.swt.widgets: Improve intensity graph drawing performance by using pixel lookup table. Szalata, Zenon M.
Next: Re: o.c.swt.widgets: Improve intensity graph drawing performance by using pixel lookup table. Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Configuring an IOC to -not- build for host arch Angus Gratton
Next: vlinac and point release Akridge, Charles S. (MSFC-ES52)
ANJ, 20 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
