1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: softIOC and SIGHUP
To: Ralph Lange <[email protected]>
Cc: [email protected]
Date: Tue, 21 Sep 2010 03:50:20 -0700
Hello Ralph,
On Mon, Sep 20, 2010 at 10:23, Ralph Lange <[email protected]> wrote:
> I agree that it generally would be better to check the SIGHUP handling
> before changing it.
> Did you try if changing that behavior fixes the issue you are seeing?
I've patched src/libCom/osi/os/posix/osdSignal.cpp to check first if
SIGHUP is ignored. Handler is not installed and signal is not
unblocked if the existing action is SIG_IGN. This fixes the response
to SIGHUP when running under nohup (both under glibc and uClibc).
> It would be great if you opened a bug report against the Launchpad bug
> tracker for EPICS Base [1] to report this issue. (And maybe even file a
> patch if you were able to fix it.) Thanks a lot!
Done (with a patch).
> Also, is there any particular reason to not run the IOC inside a wrapper
> like procServ [2]? That would remove the need to use nohup in the first
> place.
I've learned of procServ fairly recently and have not had a chance to
investigate it in depth. Overall, since nohup does (or at least used
to do) exactly what's needed, I've looked no further. Application in
question does not tolerate IOC restarts, so if the IOC dies for any
reason we want to know about it. I understand that procServ is very
powerful and flexible, but there so many other problems to work on :(
Dmitry Teytelman
Re: softIOC and SIGHUP Ralph Lange
softIOC and SIGHUP Dmitry Teytelman
Prev: Re: sequencer beta release Goetz Pfeiffer
Next: RE: Stream Device With Parameters Gorka Ronda
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: softIOC and SIGHUP Mark Rivers
Next: Re: softIOC and SIGHUP Ralph Lange
ANJ, 21 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
