1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: softIOC and SIGHUP
To: Dmitry Teytelman <[email protected]>
Cc: [email protected]
Date: Tue, 21 Sep 2010 10:10:36 -0400
Hello Dmitry,
On 21-Sep-2010 06:50, Dmitry Teytelman wrote:
Hello Ralph,
On Mon, Sep 20, 2010 at 10:23, Ralph Lange<[email protected]> wrote:
It would be great if you opened a bug report [...]
Done (with a patch).
Great, thanks a lot!!
Also, is there any particular reason to not run the IOC inside a wrapper
like procServ [2]? That would remove the need to use nohup in the first
place.
I've learned of procServ fairly recently and have not had a chance to
investigate it in depth. Overall, since nohup does (or at least used
to do) exactly what's needed, I've looked no further. Application in
question does not tolerate IOC restarts, so if the IOC dies for any
reason we want to know about it. I understand that procServ is very
powerful and flexible, but there so many other problems to work on :(
That's fine, of course. Just wanted to know your motivation.
The two main things that procServ would give you in this case are access to your IOC console through telnet (while it's running), and logging the console output to a file (to find out why it died). Auto-reboot is configurable.
</advertisement>
Cheers,
Ralph
softIOC and SIGHUP Dmitry Teytelman
Re: softIOC and SIGHUP Ralph Lange
Re: softIOC and SIGHUP Dmitry Teytelman
Prev: RE: Stream Device With Parameters Gorka Ronda
Next: Re: vlinac and point release Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: softIOC and SIGHUP Dmitry Teytelman
Next: RE: o.c.swt.widgets: Improve intensity graph drawing performance by using pixel lookup table. Szalata, Zenon M.
ANJ, 21 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
