1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Long string ...
To: [email protected]
Date: Mon, 27 Sep 2010 17:57:24 -0400
Hi Emmanuel,
On 27.09.2010 15:17, [email protected] wrote:
Pete,
That doesn't seem to work either (at least with a stringout record)
epics2@cr1com1 $ caput DMC2183:4:SO.VAL$ "111345678901234567890123456789012345678901234567890"
Old : DMC2183:4:SO.VAL$ 40 84 80 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
New : DMC2183:4:SO.VAL$ 40 -1 80 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
I am not sure how to read this, but the number 40 probably means that the stringout is limited to 40 chars.
As Nick already pointed out in his mail,
On 27.09.2010 04:43, [email protected] wrote:
  * You need to be putting the data into a record field that is large
enough to take the data. Hence, the stringOut record is still limited by
the 40 character hard size of the field definition. If you are using
stream device you can use a waveform record with a FTVL of CHAR or
UCHAR. You can also use the asynRecord.
Let me rephrase that:
Even with the '$' long string modifier that the database understands in 3.14.11, you will not be able to write more that 40 characters into a field that is only 40 characters long.
If your record has a string field that holds more than 40 characters or is an array of type CHAR with more than 40 elements (like the NAME field of all records, or the data fields of a properly configured waveform or asynRecord), you can use the '$' notation to read and write long strings. (Andrews remarks apply.)
Cheers,
Ralph
Long string ... emmanuel_mayssat
Re: Long string ... Pete R. Jemian
Re: Long string ... emmanuel_mayssat
Prev: Re: Long string ... Andrew Johnson
Next: RE: Soft IOCs and Port Numbers Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: always more inputs in gensub/asub emmanuel_mayssat
ANJ, 27 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
