I like the idea of having a RDB to do channel archiving. But compared to files it obviously increases the complexity. Yes, the complexity is an issue. For the SNS, the complexity of handling the data was the issue which led to the RDB based archiver. With the previous file based archiver and a 2GB file size limit, the difficulty was in dealing with lots of sub-archives, moving data from the archive engine servers to a data server for client retrieval, lots of archive engines each with their local configuration, long term disk storage issues, etc. It was also difficult to understand what was actually going into the archiver at what rate and producing how much data. Moreover, options for decimating or selectively purging old data were pretty much not possible. The RDB back-end simplifies much of this. Let the RDB handle the data. Additionally, keep all of the archive engine configurations in a central database. Now it becomes possible to use standard database techniques to look at the data and the configuration: which PVs have a sample in this period of time? how many samples has a particular archive engine inserted in the past 2 hours? which archive engine is archiving this PV (while ensuring that only _one_ engine actually is archiving it)? Simple web tools can be used to review or update the archive engine configurations in the RDB. SQL can be used to retrieve the data. (Decimating or selectively purging old data and long term storage are still issues, though. The primary issue is more of policy: deciding what and when. The RDB makes it technically possible, but there is still uncertainty with actual performance of purging) But the trade-off with the ease in data handling is the increase complexity in the initial setup. You need an RDB and maybe a DBA. You find issues with 'extending table space' and 'redo log files' and other fun stuff. I went through the doc and it says that Oracle can handle 8000 pv updates per second. Were any benchmark done with a mysql backend? Yes, but I don't have the numbers. Short answer: mysql was faster, but less extensible. Ultimately the population of the database (creation of tables) should be 'automated' and starting from a 'dbl <recordType> > ... '. It's certainly possible, but in the case of SNS, we don't necessarily want all ~500,000 records to be archived. Tying it in with irmis tables should also be possible if you are interested in trying that. But the doc mentions we should be using eclipse and this and that. For this simple operation, that seems a little complicated and overkill... The archive engine is a 'headless' css application so that implies eclipse. -- Steven Hartman [email protected] || 865-466-6473
ANJ, 30 Sep 2010 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
