1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gateway putlog
To: [email protected]
Cc: [email protected]
Date: Tue, 12 Oct 2010 09:06:07 -0500
Hi Patrick,
On Friday 08 October 2010 21:10:26 [email protected] wrote:
> I was wondering where the writes to the put log are done in the gateway
> source code? I would like to try to modify the source to allow multiple
> gateways to write this information to a central database, but I'm having a
> bit of a hard time finding the calls in the code.
I believe this is done through an Access Security hook, so the gateway calls
an asLib routine to check rights and that calls back into the hook routine.
If you look at the documentation for asLib in the Application Developers'
Guide you should find something about that, but if not ask again and I'll go
hunting.
HTH,
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: gateway putlog Ben Franksen
gateway putlog pthomas
Prev: No motion and No homeStatus motor:6.51/VxWorks:6.8/base 3.14.11: No change with a new motor.h Jerome HOSSELET
Next: Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: gateway putlog pthomas
Next: Re: gateway putlog Ben Franksen
ANJ, 12 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
