1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11
To: [email protected]
Cc: Jerome HOSSELET <[email protected]>
Date: Tue, 12 Oct 2010 09:50:55 -0500
Hi Jerome,
On Monday 11 October 2010 10:08:02 Jerome HOSSELET wrote:
> I have some troubles with a motor driver v 6.5.1 and EPICS base 3.14.11 and
> VxWorks 6.8
> VxWorks 6.8 : install ok
> Base EPICS 3.14.11 : compilation ok
> Support motor 6.5.1: compilation ok
We found a problem with our munching of vxWorks binaries when used with the
later vxWorks 6.x versions that use the GNU C++ 4.x compilers, and I wonder if
this might be related to what you're experiencing since I believe the Motor
record has C++ code in it.  There is a patch on the Known Problems page for
R3.14.11 which you should try in case it fixes the issue (and you should
probably look at the other patches there too in case any of them apply to your
usage):
http://www.aps.anl.gov/epics/base/R3-14/11-docs/KnownProblems.html
HTH,
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Jerome HOSSELET
Prev: Re: gateway putlog Andrew Johnson
Next: Re: gateway putlog Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Daron Chabot
Next: Timeout errors with ASYN Modbus Driver 2.0 David Dudley
ANJ, 12 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
