1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gateway putlog
To: [email protected]
Cc: [email protected]
Date: Fri, 15 Oct 2010 09:49:41 -0400
Hello Patrick,
the caPutLog facility uses a plug-in interface in the access security library, installing a hook that writes to the log.
You need to download and compile the caPutLog facility. This code will call logClientSend - maybe not directly.
This code will also have an initialization routine, which has to be called to make it register its log-sending routine into the access security layer. This initialization will be called automatically (through the registrar facility) on IOCs, a host application like the Gateway will have to call it manually when it starts up.
Your application (Gateway) is being linked against the access security layer library. The source code of that library contains the asTrapWriteRegisterListener routine that the caPutLog facility calls to install its log-sending routine.
So...
After downloading and compiling the caPutLog module, you will have to add the generated caPutLog library to the list of libraries that the Gateway is linked against. (In the Gateway's Makefile.)
You will also have to add the call to caPutLog's init routine to the Gateway code, in a place where it gets called early enough.
Last, you must configure the Gateway's access control configuration to actually run the trap-write hook for the channels you want to monitor access for.
Hope this made things more clear...
Ralph
On 15-Oct-2010 04:45, [email protected] wrote:
I'm sorry, I'm not quite sure I understand. I did a grep for
asTrapWriteRegisterListener and logClientSend in the gateway source code
and did not get any results. Is there code in the gateway source somewhere
that does the logging to the file that is specified on the command line?
Thank you,
Patrick
On 12-Oct-2010 13:51, Ben Franksen wrote:
On Dienstag, 12. Oktober 2010, Andrew Johnson wrote:
On Friday 08 October 2010 21:10:26 [email protected] wrote:
I was wondering where the writes to the put log are done in the
gateway source code? I would like to try to modify the source to
allow multiple gateways to write this information to a central
database, but I'm having a bit of a hard time finding the calls in
the code.
I believe this is done through an Access Security hook, so the
gateway calls an asLib routine to check rights and that calls back
into the hook routine. If you look at the documentation for asLib in
the Application Developers' Guide you should find something about
that, but if not ask again and I'll go hunting.
Right, at least that is how it is done on the IOC. You can even
configure put logging in the access security configuration file; IIRC
the gateway has such a file, too.
Note that --again, this is how it works on the IOC-- neither access
security, nor any other part of the IOC knows anything about caPutLog.
Instead, the initialization routine of the caPutLog facility registers
a callback with access security (calling asTrapWriteRegisterListener),
which in turn does the actual logging via calls to logClientSend (see
src/libCom/logClient in base).
Correct.
As the Gateway uses the same access security library as the IOC, to use
caPutLog you would have to link the Gateway against the caPutLog code
compiled for your architecture, and probably call caPutLog's
initialization routine manually somewhere from within main() or one of
the main classes to make sure caPutLog registers with access security
early enough.
Once you have it working, please send a patch and/or a description, as
others might want to do the same and could benefit from your work.
That's probably at least worth a readme or a page on the wiki.
Good luck!
Ralph
gateway putlog pthomas
Re: gateway putlog Andrew Johnson
Re: gateway putlog Ben Franksen
Re: gateway putlog Ralph Lange
Re: gateway putlog pthomas
Prev: Re: Problem in registerRecordDeviceDriver Ralph Lange
Next: Re: Problem in registerRecordDeviceDriver Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: gateway putlog pthomas
Next: Re: gateway putlog Andrew Johnson
ANJ, 15 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
