1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics C# Library - questions
To: [email protected]
Date: Tue, 19 Oct 2010 07:04:59 +0200
No you don't need anything, monitors are just matter of creating the channel with the factory, and then subscribe to the events as shown in the web page (http://gfa-it.web.psi.ch/epicsSharp/index.php?site=examples).
If you need to access the channels via some gateway or others then you will have either to configure your EpicsClient inside the code or provide the app.config
Sincerely,
Alain Bertrand
On 18/10/2010 17:16, Jose Patricio Gonzalez wrote:
Hello
I'm starting to use the Epics C# Library
(http://gfa-it.web.psi.ch/epicsSharp) with the EPICS monitor included
in that page, but I'm unable to read data from that monitor with the
examples
What do I have to set to run it? do I need some external libraries?
Thanks so much !
Joe
Epics C# Library - questions Jose Patricio Gonzalez
Prev: RE: EPICS CA problems Mark Rivers
Next: RE: Eurotherm Temperature Controller Support emma.shepherd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Epics C# Library - questions Jose Patricio Gonzalez
Next: Lookup table problem Silver
ANJ, 21 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
