1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS CA problems
To: "tech-talk" <[email protected]>, "Jeff Hill" <[email protected]>
Cc: Antonio Lanzirotti <[email protected]>
Date: Mon, 18 Oct 2010 20:57:42 -0500
Folks,
I learned today that it appears that caRepeater has been crashing on this system.  I don't know for sure that this problem happens when caRepeater has died, but that seems likely.  The next time it happens we will look to see if caRepeater is still running.
Meanwhile, we have found that there are caRepeater stackdump files, containing the following:
Exception: STATUS_ACCESS_VIOLATION at eip=610B9F69
eax=00000000 ebx=00000001 ecx=00000000 edx=0014C6F0 esi=00000000 edi=011DCCD8
ebp=011DCB14 esp=011DCAEC program=C:\Program Files\EPICS WIN32 Extensions\caRepeater.exe, pid 2152, thread unknown (0xC44)
cs=001B ds=0023 es=0023 fs=003B gs=0000 ss=0023
Stack trace:
Frame     Function  Args
011DCB14  610B9F69  (00000000, 00000000, 00000000, 00000000)
011DCC24  610BA905  (00000000, 00000000, 00000000, 00000000)
011DCCE4  610BB67A  (FFFFFFFF, FFFFFFFF, 00000000, 00000000)
011DCD34  61027DE2  (00000002, 011DCE64, 00000002, 011DCE00)
011DCDC8  7C87655C  (00000002, 011DCE00, 7C8763C0, 00000002)
End of stack trace
Has anyone else seen such stackdumps from caRepeater?  This is the version of caRepeater.exe that is included in the most recent (Nov. 2, 2007) APS "EPICS Win32 Extensions" package.
Sent: Wed 10/13/2010 11:14 AM
To: tech-talk; 'Jeff Hill'
Subject: EPICS CA problems
Folks,
We are having trouble with a Windows IOC at NSLS.  Here are the symptoms:
- The IOC is running fine
- The PC running the IOC has 2 local CA clients connected to the IOC, medm and IDL.  Occassionally (1-2 times per day) one of these clients loses its connection to the IOC.  Medm screens go white, IDL says it cannot find a PV, etc.  This happens when the client was running fine.  It typically only happens to one or the other client, not to both.
- Restarting the client fixes the problem.
- The same 2 clients are running on another PC connected to the same IOC.  Those clients are always fine, they do not lose connection when a client on the PC with the IOC does.
- Looking at the resources on the Windows machine (CPU, virtual and physical memory usage) does not indicate any problems.
How do we go about figuring out what is wrong?
RE: EPICS CA problems Jeff Hill
EPICS CA problems Mark Rivers
Prev: Re: Manipulating time in records Andrew Johnson
Next: Re: Epics C# Library - questions Alain Bertrand
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS CA problems Jeff Hill
Next: RE: EPICS CA problems Jeff Hill
ANJ, 19 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
