1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS CA problems
To: "tech-talk" <[email protected]>, "Jeff Hill" <[email protected]>
Cc: Antonio Lanzirotti <[email protected]>
Date: Wed, 13 Oct 2010 11:14:54 -0500
Folks,
We are having trouble with a Windows IOC at NSLS.  Here are the
symptoms:
- The IOC is running fine
- The PC running the IOC has 2 local CA clients connected to the IOC,
medm and IDL.  Occassionally (1-2 times per day) one of these clients
loses its connection to the IOC.  Medm screens go white, IDL says it
cannot find a PV, etc.  This happens when the client was running fine.
It typically only happens to one or the other client, not to both.
- Restarting the client fixes the problem.
- The same 2 clients are running on another PC connected to the same
IOC.  Those clients are always fine, they do not lose connection when a
client on the PC with the IOC does.
- Looking at the resources on the Windows machine (CPU, virtual and
physical memory usage) does not indicate any problems.
How do we go about figuring out what is wrong?
Re: EPICS CA problems Tim Mooney
Re: EPICS CA problems J. Lewis Muir
RE: EPICS CA problems Jeff Hill
RE: EPICS CA problems Mark Rivers
Prev: Re: Calling an iocsh "sub-script" Josh Stein
Next: Re: EPICS CA problems Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Calling an iocsh "sub-script" emmanuel_mayssat
ANJ, 18 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
