1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Calling an iocsh "sub-script"
Date: Thu, 14 Oct 2010 09:27:07 -0700
Angus,
An even better trick I found (since iocsh is not scriptable)
is something like this
< device.defaultValues               # a set of epicsEnvSet entries
epicsEnvSet(NAME, "instance1")       # overwrite default values
< device.cmd                         # create an instance of the device
With a trick like this, you can develop the driver
without interfering with the existing instances or modifying past stcmd files.
For example, if you want to add a feature to a driver, you just need to supply
default values for the device already instanciated.
You can push this even further
A subsystem (ex allMyAdcs) is a group of device
< adc1
#< adc2
Another high-level subsystem (ex bpm)
< allMyAdcs
< allMyDacs
< pvAliasAndOtherSoftVariables
An ioc is a group of subsystems
< kicker
< bpm
Now to troubleshoot an IOC, you can just comment out what should not run
when the ioc is started. With the configuration above the adc2 will not be started.
You can actually start it in another IOC and bring it up and down at your will.
With a setup like this you can troubleshoot a synchrotron while operators are using it.
Only the smallest parts that needs to be troubleshooted is down.
The rest is up and operational.
You can even push this even further --  but in the other direction -- and separate the preIocInit and postIocInit sequences.
In preIocInit scripts you create the instances, set the var, start iocshScript.
In postIocInit scripts you can test the instance was loaded correctly, start sequencer
In stcmd you load default paths, dbl * > nfsFile, etc.
Enjoy!
Emmanuel
On 18:21 Tue 12 Oct     , Mark Rivers wrote:
> How about the following using the "<" to read another file:
> # other ioc commands go here
> epicsEnvSet MY_ENV A
> < mychildscript.cmd
> epicsEnvSet MY_ENV B
> < mychildscript.cmd
> # more ioc commands go here
Calling an iocsh "sub-script" Angus Gratton
RE: Calling an iocsh "sub-script" Mark Rivers
Prev: Re: Calling an iocsh "sub-script" Eric Norum
Next: RE: EPICS CA problems Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS CA problems Mark Rivers
ANJ, 14 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
