1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Calling an iocsh "sub-script"
To: "Angus Gratton" <[email protected]>, "tech-talk" <[email protected]>
Date: Tue, 12 Oct 2010 18:21:56 -0500
How about the following using the "<" to read another file:
# other ioc commands go here
epicsEnvSet MY_ENV A
< mychildscript.cmd
epicsEnvSet MY_ENV B
< mychildscript.cmd
# more ioc commands go here
-----Original Message-----
[mailto:[email protected]] On Behalf Of Angus Gratton
Sent: Tuesday, October 12, 2010 6:20 PM
To: tech-talk
Subject: Calling an iocsh "sub-script"
Is it possible to call subscripts from a parent iocsh script? ie
iocsh mychildscript.cmd
This seems like it should be possible, but the app dev guide has left me
drawing a blank. The "iocsh <script>" command that's available in
VxWorks would do it, but it isn't available on RTEMS.
I was thinking of writing a thin wrapper around the C function iocsh()
and exporting that, but that seems like it might not work if it is not
available now.
Particularly, I'm keen to do is pass the parent environment context to
the child. Is that possible?
Explanation: The reason that I want to do this is that I have two banks
of Group 3 DI interfaces that are both configured identically on
separate loops, ie my .cmd initialisation code has:
initGP3TypeD L1D0B1, L1, 0, 1
initGP3TypeD L1D0B2, L1, 0, 2
initGP3TypeD L1D0B3, L1, 0, 3
initGP3TypeD L2D0B1, L2, 0, 1
initGP3TypeD L2D0B2, L2, 0, 2
initGP3TypeD L2D0B3, L2, 0, 3
(for around 15 init statements each)
and I'd like to be able to do:
initGP3TypeD ${LOOP}D0B1, ${LOOP}, 0, 1
initGP3TypeD ${LOOP}D0B2, ${LOOP}, 0, 2
initGP3TypeD ${LOOP}D0B3, ${LOOP}, 0, 3
... and then call that script file twice with environment variable
LOOP=L1 and LOOP=L2, to save on copy-paste.
- Angus
RE: Calling an iocsh "sub-script" Angus Gratton
Re: Calling an iocsh "sub-script" Josh Stein
Re: Calling an iocsh "sub-script" emmanuel_mayssat
Prev: Calling an iocsh "sub-script" Angus Gratton
Next: RE: Calling an iocsh "sub-script" Angus Gratton
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 14 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
