1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Calling an iocsh "sub-script"
To: tech-talk <[email protected]>
Date: Wed, 13 Oct 2010 10:08:12 -0500
I would like to point out one warning with these embedded scripts - there is a very real possibility of breaking some higher level tools which rely on 'crawling' the startup command files for information. This very issue has just cropped up here at APS when the st.cmd structure of a number of our production IOCs was cleaned up during a recent 3.14 upgrade.
In essence, some of our crawlers were unable to parse relevant tags since they failed to show up in the st.cmd file itself as those tags were moved to one or more of the 'sub-scripts'.
For now, the crawlers at APS are being re-written to follow the indirection. This is yet another example of how fragile the system structure can grow over time; the hooks into various parts actually increase the risk of things breaking as time progresses.
--J
Mark Rivers wrote:
How about the following using the "<" to read another file:
# other ioc commands go here
epicsEnvSet MY_ENV A
< mychildscript.cmd
epicsEnvSet MY_ENV B
< mychildscript.cmd
# more ioc commands go here
-----Original Message-----
[mailto:[email protected]] On Behalf Of Angus Gratton
Sent: Tuesday, October 12, 2010 6:20 PM
To: tech-talk
Subject: Calling an iocsh "sub-script"
Is it possible to call subscripts from a parent iocsh script? ie
iocsh mychildscript.cmd
This seems like it should be possible, but the app dev guide has left me
drawing a blank. The "iocsh <script>" command that's available in
VxWorks would do it, but it isn't available on RTEMS.
I was thinking of writing a thin wrapper around the C function iocsh()
and exporting that, but that seems like it might not work if it is not
available now.
Particularly, I'm keen to do is pass the parent environment context to
the child. Is that possible?
Explanation: The reason that I want to do this is that I have two banks
of Group 3 DI interfaces that are both configured identically on
separate loops, ie my .cmd initialisation code has:
initGP3TypeD L1D0B1, L1, 0, 1
initGP3TypeD L1D0B2, L1, 0, 2
initGP3TypeD L1D0B3, L1, 0, 3
initGP3TypeD L2D0B1, L2, 0, 1
initGP3TypeD L2D0B2, L2, 0, 2
initGP3TypeD L2D0B3, L2, 0, 3
(for around 15 init statements each)
and I'd like to be able to do:
initGP3TypeD ${LOOP}D0B1, ${LOOP}, 0, 1
initGP3TypeD ${LOOP}D0B2, ${LOOP}, 0, 2
initGP3TypeD ${LOOP}D0B3, ${LOOP}, 0, 3
... and then call that script file twice with environment variable
LOOP=L1 and LOOP=L2, to save on copy-paste.
- Angus
Re: Calling an iocsh "sub-script" Ben Franksen
Re: Calling an iocsh "sub-script" J. Lewis Muir
Calling an iocsh "sub-script" Angus Gratton
RE: Calling an iocsh "sub-script" Mark Rivers
Prev: RE: Calling an iocsh "sub-script" Angus Gratton
Next: EPICS CA problems Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Calling an iocsh "sub-script" Ben Franksen
ANJ, 13 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
