The calc module (http://www.aps.anl.gov/bcda/synApps/calc/calc.html) has an
example of this (the interp.db database, and the interp.c aSub routine),
though
with only two lookup-table arrays. (That is, it maintains arrays X,
Y1(X), Y2(X).)
Interp has some extra stuff you probably don't want, as it supports
building lookup
tables point-by-point at run time, and it can interpolate with a
polynomial of order 1-10.
It uses autosave to load arrays (also to save them, if they are modified
at run time).
Tim Mooney
Silver wrote:
hi,
I need to implement a function for insertion device like this:
Read a two-dimensions table file from the disk, which is values for gap positions and Correction coil power supplies (one gap value corresponding to 4 power supply value). If a gap position is set from the operator, four power supplies will be set automatically.
I want to use SNC language to do this, for reading the data from disk, use an asub record for it. Is it ok? Is there any better ways? Did anyone finish this job before?
Any suggestions are appreciated.
Best regards
Geyang 2010-10-21
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
- Lookup table problem Silver
Re: Lookup table problem Ralph Lange
Re: cross-gcc-2.9.6 problem zhuangjian
<2010>
2025
Re: Lookup table problem Ben Franksen
cross-gcc-2.9.6 problem 王林
<2010>
2025
ANJ, 21 Oct 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
