hi, all,
I re-built an IOC with ScientificLinux
5.5, base-3-14-11, asynDriver 4-12, and streamDevice2.4.
Linux, base, and asynDriver were installed OK.
Following errors occured when I compiled streamDevice2-4.
Does anyone give us instructions?
Thanks in advance.
Jianguo Ding
SSRF Control group
[root@localhost StreamDevice-2-4]# make make -C
./src install make[1]: Entering directory
`/root/apps/StreamDevice-2-4/src' perl
/usr/local/epics/base/base-3-14-11/bin/linux-x86/makeMakefile.pl O.linux-x86
../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../..
T_A=linux-x86 install make[2]: Entering directory
`/root/apps/StreamDevice-2-4/src/O.linux-x86' Installing created dbd file
../../../dbd/stream.dbd /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L
-D_POSIX_THREADS
-D_XOPEN_SOURCE=500
-D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT
-O3 -Wall -m32
-g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux
-I../../../include -I/usr/local/epics/base/base-3-14-11/include/os/Linux
-I/usr/local/epics/support/asyn-4.12/include
../AsynDriverInterface.cc ../AsynDriverInterface.cc: In member function
‘void AsynDriverInterface::writeHandler()’: ../AsynDriverInterface.cc:630:
warning: enumeration value ‘asynDisconnected’ not handled in
switch ../AsynDriverInterface.cc:630: warning: enumeration value
‘asynDisabled’ not handled in switch ../AsynDriverInterface.cc: In member
function ‘void
AsynDriverInterface::readHandler()’: ../AsynDriverInterface.cc:810: warning:
switch ../AsynDriverInterface.cc:810: warning: enumeration value
‘asynDisabled’ not handled in switch /usr/bin/g++ -c
-D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500
-O3 -Wall -m32
../EnumConverter.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L
-D_POSIX_THREADS
-D_XOPEN_SOURCE=500
-O3 -
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500
-O3 -Wall -m32
../devwaveformStream.c ../devwaveformStream.c: In function
‘readData’: ../devwaveformStream.c:52: warning: implicit declaration of
function ‘errlogSevPrintf’ ../devwaveformStream.c:52: error: ‘errlogFatal’
undeclared (first use in this function) ../devwaveformStream.c:52: error:
(Each undeclared identifier is reported only once ../devwaveformStream.c:52:
error: for each function it appears in.) ../devwaveformStream.c:132: error:
‘errlogMajor’ undeclared (first use in this function) ../devwaveformStream.c:
In function ‘writeData’: ../devwaveformStream.c:184: error: ‘errlogFatal’
undeclared (first use in this function) make[2]: *** [devwaveformStream.o]
Error 1 make[2]: Leaving directory
`/root/apps/StreamDevice-2-4/src/O.linux-x86' make[1]: ***
[install.linux-x86] Error 2 make[1]: Leaving directory
`/root/apps/StreamDevice-2-4/src' make: *** [src.install] Error
2 [root@localhost StreamDevice-2-4]#
- Re: build streamDevice 2-4 error Rod Nussbaumer
Re: monitors received out of order Kate Feng
Modbus R2-1 available Mark Rivers
<2010>
RE: Options for reviving old Allen Bradley PLC implementations Bryce Karnaghan
<2010>
ANJ, 08 Nov 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
