#include <errlog.h> to the list of header files included. Rod Nussbaumer ISAC Controls, TRIUMF Vancouver, Canada. Ding Jianguo wrote: hi, all, I re-built an IOC with ScientificLinux 5.5, base-3-14-11, asynDriver 4-12, and streamDevice2.4. Linux, base, and asynDriver were installed OK. Following errors occured when I compiled streamDevice2-4. Does anyone give us instructions? Thanks in advance. Jianguo Ding SSRF Control group [root@localhost StreamDevice-2-4]# make make -C ./src install make[1]: Entering directory `/root/apps/StreamDevice-2-4/src' perl /usr/local/epics/base/base-3-14-11/bin/linux-x86/makeMakefile.pl O.linux-x86 ../../.. mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[2]: Entering directory `/root/apps/StreamDevice-2-4/src/O.linux-x86' Installing created dbd file ../../../dbd/stream.dbd /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/local/epics/base/base-3-14-11/include/os/Linux -I/usr/local/epics/base/base-3-14-11/include -I/usr/local/epics/support/asyn-4.12/include ../AsynDriverInterface.cc ../AsynDriverInterface.cc: In member function ‘void AsynDriverInterface::writeHandler()’: ../AsynDriverInterface.cc:630: warning: enumeration value ‘asynDisconnected’ not handled in switch ../AsynDriverInterface.cc:630: warning: enumeration value ‘asynDisabled’ not handled in switch ../AsynDriverInterface.cc: In member function ‘void AsynDriverInterface::readHandler()’: ../AsynDriverInterface.cc:810: warning: enumeration value ‘asynDisconnected’ not handled in switch ../AsynDriverInterface.cc:810: warning: enumeration value ‘asynDisabled’ not handled in switch /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/local/epics/base/base-3-14-11/include/os/Linux -I/usr/local/epics/base/base-3-14-11/include -I/usr/local/epics/support/asyn-4.12/include ../EnumConverter.cc /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 - ......................
ANJ, 08 Nov 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
