1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Last chance to save the sequencer's pv layer
To: Ben Franksen <[email protected]>
Cc: [email protected]
Date: Mon, 15 Nov 2010 11:27:46 -0500
Hi Ben,
On Sunday 14 November 2010 11:25:47 Ben Franksen wrote:
> If you are using the pv layer for anything (other than as obligatory
> bridge to CA as required by previous sequencer versions), or if you
> think that there are other important reasons to keep it, this is your
> last chance to save it, otherwise it's going to pay its debt to nature.
Fine by me.
While you're making sequencer changes, could you replace all instances of
OFFSET(s,m) (from dbDefs.h) with the standard macro offsetof(s,m) in the
sequencer code; I'd like to retire that macro in the 3.15 releases since it
really is a direct replacement and I think the sequencer is its last major
user.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: Last chance to save the sequencer's pv layer Ben Franksen
Attention, poll: Who needs the sequencer's pv layer? Ben Franksen
Prev: about the cPCI/EPICS system of APS/LBNL 王林
Next: Re: EPICS base on Windows with INSTALL_LOCATION on a different drive Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Last chance to save the sequencer's pv layer Ben Franksen
Next: Re: Last chance to save the sequencer's pv layer Ben Franksen
ANJ, 15 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
