1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Last chance to save the sequencer's pv layer
To: [email protected]
Date: Mon, 15 Nov 2010 19:56:35 +0100
Hi Andrew
On Montag, 15. November 2010, Andrew Johnson wrote:
> On Sunday 14 November 2010 11:25:47 Ben Franksen wrote:
> > If you are using the pv layer for anything (other than as
> > obligatory bridge to CA as required by previous sequencer
> > versions), or if you think that there are other important reasons
> > to keep it, this is your last chance to save it, otherwise it's
> > going to pay its debt to nature.
> Fine by me.
Good.
> While you're making sequencer changes, could you replace all
> instances of OFFSET(s,m) (from dbDefs.h) with the standard macro
> offsetof(s,m) in the sequencer code; I'd like to retire that macro in
> the 3.15 releases since it really is a direct replacement and I think
> the sequencer is its last major user.
The sequencer defines its own version (in seqCom.h) if it is not already
defined; anyway I already removed it in my working version, so consider
it done ;-)
Cheers
Ben
Attention, poll: Who needs the sequencer's pv layer? Ben Franksen
Last chance to save the sequencer's pv layer Ben Franksen
Re: Last chance to save the sequencer's pv layer Andrew Johnson
Prev: Re: asyn driver on Windows XP Eric Norum
Next: Stand-alone sequencer programs Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Last chance to save the sequencer's pv layer Andrew Johnson
Next: Re: Last chance to save the sequencer's pv layer Ben Franksen
ANJ, 15 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
