1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Last chance to save the sequencer's pv layer
To: [email protected]
Date: Mon, 15 Nov 2010 21:40:29 +0100
On Sonntag, 14. November 2010, Ben Franksen wrote:
> On Freitag, 29. Oktober 2010, Ben Franksen wrote:
> > this is a poll to determine whether anyone is actually using the
> > sequencer with backends other than Channel Access and so needs
> > support for the pv layer between the sequencer and the backend data
> > transfer protocol.
> > I would rather like to get rid of the pv layer for several reasons.
> The people at KECK have told me they discussed it and have decided
> they no longer need the KTL support, quote: "We're all for
> simplifying it!"
> So, one last time:
> If you are using the pv layer for anything (other than as obligatory
> bridge to CA as required by previous sequencer versions), or if you
> think that there are other important reasons to keep it, this is your
> last chance to save it, otherwise it's going to pay its debt to
> nature.
Since I have received questions off-list, like
> What exactly do you mean by "the pv layer"?
> We may be using it, but I'd have to look at the code.
which indicate that I have assumed to much knowledge of the sequencer
internals, let me add some explanations:
I am talking about the code under src/pv in the sequencer source tree.
This code provides a C++ implementation of a CA-client-like interface,
so that you can use the sequencer with other protocols (that provide
similar features) beside CA (such as KECK's KTL library). It has been
introduced in version 2.0.
The current sequencer interface (and thus most existing SNL programs)
need only the header file pvAlarm.h in which CA status codes and EPICS
record status/severity are unified as pvStatXXX and pvSevrXXX. This
header file will remain available to provide compatibility for existing
programs. What I want to abandon is the *internal* use of the pv
library, i.e. the C++ layer over CA.
With "using the pv layer" I mean that you use the sequencer with
protocols other than CA, or that you have programs that directly use
the C *functions* or C++ *classes* defined in pv.h.
Cheers
Ben
"Never confuse what is natural with what is habitual."
                                   -- attributed to Mahatma Gandhi
Re: Last chance to save the sequencer's pv layer Maren Purves
Attention, poll: Who needs the sequencer's pv layer? Ben Franksen
Last chance to save the sequencer's pv layer Ben Franksen
Prev: Re: Stand-alone sequencer programs Ben Franksen
Next: EPICS Base R3.14.12-rc1 now available Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Last chance to save the sequencer's pv layer Ben Franksen
Next: Re: Last chance to save the sequencer's pv layer Maren Purves
ANJ, 15 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
