1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stand-alone sequencer programs
To: [email protected]
Date: Mon, 15 Nov 2010 21:10:46 +0100
On Montag, 15. November 2010, Andrew Johnson wrote:
> On Monday 15 November 2010 13:22:39 Ben Franksen wrote:
> > > > While you're making sequencer changes, [...]
> > ...would anyone be sad if I removed the -s switch for stand-alone
> > sequencer programs (i.e. those which which have been compiled
> > with 'snc -m' and thus contain a main function) and instead always
> > start them with an iocsh?
> > The problem is that it is easy to forget the -s switch which leaves
> > you with a program that cannot be interrupted other than with a
> > kill -9 (SIG_TERM). This is just annoying and I don't see a
> > compelling use case.
> > A compromise would be to just reverse the default, so you'd need an
> > extra switch to say 'no ioc shell'.
> That's what I did with the softIoc binary in Base; it used to need a
> -s option to enable the IOC shell, now it needs a -S switch to
> disable the IOC shell instead. A -s is still accepted, but does
> nothing.
Cool, so I'll copy this behaviour for the sequencer.
Thanks
Ben
"Never confuse what is natural with what is habitual."
                                   -- attributed to Mahatma Gandhi
Stand-alone sequencer programs Ben Franksen
Re: Stand-alone sequencer programs Andrew Johnson
Prev: Re: Stand-alone sequencer programs Andrew Johnson
Next: Re: Last chance to save the sequencer's pv layer Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS Base R3.14.12-rc1 now available Andrew Johnson
ANJ, 15 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
