Subject: |
Re: whether PPC604 in vxWorks5.5.1 include PowerPC 750GX |
Ralph Lange <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Thu, 18 Nov 2010 11:34:52 -0500 |
On 08.11.2010 04:44, çæ wrote:
Hello all,
I have a question about PowerPC 750GX in vxWorks5.5 ,that is
does vxWorks5.5.1 support PowerPC 750GX processor?
For my EPICS environment, I decide to use CPCI6190 as EPICS
target, LinuxÂas EPICS host, and cross-gcc-2.9.6 from SNS as the
cross compiler. TheÂprocessor of CPCI6190 is PowerPC 750GX.
My confusion is that, in document "VxWorks5.5 for PowerPC
Architecture Supplement",it shows as follows, which says PowerPC
750GX does not belong to PPC604.
Not really true. The document does not say that the 750GX is not
part of the PPC604 architecture. It doesn't mention the 750GX at
all, which is understandable, as the 750GX did not exist when
VxWorks 5.5 came out.
While in document "vxworks architecture supplement 6.7", it
shows as follows, which says PowerPC 750GX belongs to PPC604. ![](jpg00010.jpg)
Â
So, I am not sure if PPC604 in vxWorks5.5Âincludes PowerPC
750GX. Isn't theÂ"PPC604" in vxWorks5.5 and vxWorks6.7 the
same?ÂIn my EPICS environment, can I choose CPCI6190 board?
So, your question boils down to: Is anyone sucessfully running
VxWorks 5.5 on a PPC 740 GX? You might consider asking that question
on a VxWorks mailing list - these guys have more experience with the
variety of CPUs and VxWorks releases.
The other question that comes to mind: Do you have the VxWorks 5.5
BSP for the CPCI6190 board?
If yes: the board is obviously supported.
If no: Which BSP are you planning to use for the CPCI6190?
Good luck,
Ralph
- whether PPC604 in vxWorks5.5.1 include PowerPC 750GX 王林
Re: MCA (Matlab Channel Access) new version Korhonen Timo
Re: MCA (Matlab Channel Access) new version Andrew Johnson
<2010>
Re: whether PPC604 in vxWorks5.5.1 include PowerPC 750GX Andrew Johnson
EPICS Suggestions and Priorities Andrew Johnson
<2010>
ANJ, 18 Nov 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
