Hi Hinko,
its' not clear in your example how you produced a console trace for your
sub record, there is nothing obvious in your db example to make it process.
try add a FLNK, should work
> record(calc, "$(user):subInc") {
> field(SCAN, "1 second")
> field(VAL, "0")
> field(CALC, "(A+1)")
> field(INPA, "$(user):subInc.VAL NPP")
field(FLNK, "$(user):subExample")
Matthieu
On 11/24/10 11:49, Hinko Kocevar wrote:
I'm poking around the example IOC I've created with:
$ makeBaseApp.pl -t example app1
$ makeBaseApp.pl -i -t example app1
Example runs fine and records are behaving as expected, but..
I tried to experiment with subRecord, but the mySubProcess routine does
not seem to get values on INPx fields if they are not constants. I've
added following line to get INPA value inside the C function:
static long mySubProcess(subRecord *precord)
if (mySubDebug)
printf("Record %s called mySubProcess(%p)\n",
precord->name, (void*) precord);
printf("precord->a %lf\n", precord->a);
printf("precord->b %lf\n", precord->b);
return 0;
Example:
record(sub,"$(user):subExample")
field(INAM,"mySubInit")
field(SNAM,"mySubProcess")
field(INPA, "$(user):subInc")
field(INPB, "123")
field(VAL, "0")
Output from IOC:
Record hinkoHost:subcall called mySubProcess(0x9205998)
precord->a 0.000000
precord->b 123.000000
precord->a 0.000000
precord->a 0.000000
At the same time, if I monitor the $(user):subInc:
camonitor hinkoHost:subInc
hinkoHost:subInc 2010-11-24 15:45:57.346136 14
hinkoHost:subInc 2010-11-24 15:45:58.346438 15
hinkoHost:subInc 2010-11-24 15:45:59.346628 16
What am I missing?
Best regards,
Hinko
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- RE: subrecord INPx Hinko Kocevar
- subrecord INPx Hinko Kocevar
Re: ChannelArchiver build problem with 3.14.11 on Suse linux Burkhard Kolb
RE: ca_put_callback once again Jeff Hill
<2010>
<2010>
