1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: subrecord INPx
To: "Matthieu Bec" <[email protected]>, <[email protected]>
Date: Wed, 24 Nov 2010 18:04:05 +0100
Title: RE: subrecord INPx
Hi Matthieu,
I stand corrected. It was copy-paste with few manual modifications that resulted in a mistake.
Nevertheless the INPA is not being incremented when calc record increments its VAL, even with FLNK added.
Thank you!
Best Regards,
Hinko
-----Original Message-----
Sent: Wed 11/24/2010 5:33 PM
To: [email protected]
Subject: Re: subrecord INPx
Hi Hinko,
its' not clear in your example how you produced a console trace for your
sub record, there is nothing obvious in your db example to make it process.
try add a FLNK, should work
 > record(calc, "$(user):subInc") {
 > field(SCAN, "1 second")
 > field(VAL, "0")
 > field(CALC, "(A+1)")
 > field(INPA, "$(user):subInc.VAL NPP")
   field(FLNK, "$(user):subExample")
Matthieu
On 11/24/10 11:49, Hinko Kocevar wrote:
> Hi,
> I'm poking around the example IOC I've created with:
> $ makeBaseApp.pl -t example app1
> $ makeBaseApp.pl -i -t example app1
> Example runs fine and records are behaving as expected, but..
> I tried to experiment with subRecord, but the mySubProcess routine does
> not seem to get values on INPx fields if they are not constants. I've
> added following line to get INPA value inside the C function:
> static long mySubProcess(subRecord *precord)
> if (mySubDebug)
> printf("Record %s called mySubProcess(%p)\n",
> precord->name, (void*) precord);
> printf("precord->a %lf\n", precord->a);
> printf("precord->b %lf\n", precord->b);
> return 0;
> Example:
> record(sub,"$(user):subExample")
> field(INAM,"mySubInit")
> field(SNAM,"mySubProcess")
> field(INPA, "$(user):subInc")
> field(INPB, "123")
> field(VAL, "0")
> Output from IOC:
> Record hinkoHost:subcall called mySubProcess(0x9205998)
> precord->a 0.000000
> precord->b 123.000000
> precord->a 0.000000
> precord->a 0.000000
> At the same time, if I monitor the $(user):subInc:
> camonitor hinkoHost:subInc
> hinkoHost:subInc 2010-11-24 15:45:57.346136 14
> hinkoHost:subInc 2010-11-24 15:45:58.346438 15
> hinkoHost:subInc 2010-11-24 15:45:59.346628 16
> What am I missing?
> Best regards,
> Hinko
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
subrecord INPx Hinko Kocevar
Re: subrecord INPx Matthieu Bec
Prev: Re: MAXv issue Jens . Eden
Next: RE: subrecord INPx Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: subrecord INPx Matthieu Bec
Next: RE: subrecord INPx Allison, Stephanie
ANJ, 24 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
