1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: ca_put_callback once again
To: "Jeff Hill" <[email protected]>
Cc: [email protected]
Date: Wed, 24 Nov 2010 11:36:29 -0600
On Wednesday 24 November 2010 10:36:24 Jeff Hill wrote:
> Do I understand correctly, that with this source code change in dbPutNotify
> the system now sends a failure response for the put callback request when
> this situation arises? That result, while it is arguably superior to
> current behavior, isn't particularly satisfying on a functional level
> because it is creating duplicated code in the client applications.
> Presumably, now all clients need code that will keep reissuing the put
> callback request until it is successful.
One major problem is that generic code can't know whether it is safe to re-run
a put that fails for this reason or not.  If there is significant I/O or other
processing in the chain of records that leads up to the record that's busy
then it might *not* be safe to repeat the put operation.  It doesn't matter
where we propose to put the retry code, the same issue arises; only the person
designing the overall system can work out what the correct response is.
Ben's proposal at least makes it possible for the issue to be detected by a
client so that an application-specific decision can be made when this happens.
This is definitely a 3.15 (or later) change by the way, and there is already a
major modification to the putNotify code in the queue in front of this so I'm
not going to be able to apply Ben's changes for some time, giving us a chance
to work out the consequences properly.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: ca_put_callback once again Ralph Lange
RE: ca_put_callback once again Jeff Hill
Re: ca_put_callback once again Tim Mooney
Re: ca_put_callback once again Benjamin Franksen
Prev: RE: subrecord INPx Hinko Kocevar
Next: Re: subrecord INPx Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: ca_put_callback once again Jeff Hill
Next: Re: ca_put_callback once again Ralph Lange
ANJ, 24 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
