1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: ca_put_callback once again
To: [email protected]
Date: Wed, 24 Nov 2010 13:48:16 -0500
On 24.11.2010 12:36, Andrew Johnson wrote:
One major problem is that generic code can't know whether it is safe to re-run
a put that fails for this reason or not.  If there is significant I/O or other
processing in the chain of records that leads up to the record that's busy
then it might *not* be safe to repeat the put operation.  It doesn't matter
where we propose to put the retry code, the same issue arises; only the person
designing the overall system can work out what the correct response is.
Ben's proposal at least makes it possible for the issue to be detected by a
client so that an application-specific decision can be made when this happens.
+1
Returning a warning seems like the right compromise between the current behavior of returning OK (not even letting the client know that the situation occurred) and queueing/rerunning the process chain (which might be unsafe and/or unintended).
Providing the client with as much information as possible, without making assumptions of its intentions.
This is definitely a 3.15 (or later) change by the way, and there is already a
major modification to the putNotify code in the queue in front of this so I'm
not going to be able to apply Ben's changes for some time, giving us a chance
to work out the consequences properly.
For the sake of people using the sequencer under 3.14, we could make it a "known problem" and provide a patch on the EPICS web site.
~Ralph
Re: ca_put_callback once again Tim Mooney
Re: ca_put_callback once again Benjamin Franksen
RE: ca_put_callback once again Jeff Hill
Re: ca_put_callback once again Andrew Johnson
Prev: RE: subrecord INPx Hinko Kocevar
Next: [SOLVED] RE: subrecord INPx Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: ca_put_callback once again Andrew Johnson
Next: RE: ca_put_callback once again Jeff Hill
ANJ, 24 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
