Hi Andrew,
On 11/29/10 17:25, Andrew Johnson wrote:
Hi Hinko,
On Thursday 25 November 2010 04:33:31 Hinko Kocevar wrote:
perl /home/hinko/work/epics/install/bin/linux-x86/convertRelease.pl
checkRelease
EPICS/Release.pm: Circular definition of macro TOP
Please try using absolute paths instead of relative ones in your release
files, i.e. paths that (after all the macros have been substituted) start from
the root '/' of your directory tree.
That helped.
As an aside, the<base>/configure/RELEASE file should never contain the
definition of EPICS_BASE, and it doesn't need EPICS_EXTENSIONS since Base has
to be completely built before extensions anyway.
OK. I'll remove them.
Thank you!
Best regards,
Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
- makeBaseApp.pl in 3.14.12 with custom INSTALL_LOCATION Hinko Kocevar
- Re: makeBaseApp.pl in 3.14.12 with custom INSTALL_LOCATION Andrew Johnson
RE: Monitoring CPU temperature for small IOC Allison, Stephanie
Long out record PV Monitoring error in client using CaChannel-1.5 python interface Ritesh Sugandhi
<2010>
2025
Testing UIs against real databases using simulation mode Angus Gratton
<2010>
2025
