1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Long out record PV Monitoring error in client using CaChannel-1.5 python interface
To: "'Ritesh Sugandhi'" <[email protected]>, <[email protected]>
Cc: "'Di Maio Franck'" <[email protected]>
Date: Tue, 30 Nov 2010 08:57:27 -0800
The code may interpret long values as unsigned integers. Â(In some cases, that might be what you would want.)Â ÂIt will take me some time to be able to look at this.
 Pam.
Sent: November-30-10 7:53 AM
To: [email protected]
Cc: [email protected]; [email protected]; Di Maio Franck
Subject: Long out record PV Monitoring error in client using CaChannel-1.5 python interface
Dear Sir,
We are using a client application develop using CaChannel-1.5 epics python interface library. The CA server is exposing a longout record which we are interested in monitoring.  When ever the record attends the âive values. The client shows  2**32-val instead of value. while the same code works well with ao record type .
The Code is as below:
def eventMon(epics_args, user_args):
  global monPV, now
  print monPV, now, epics_args['pv_value']
def main():
  global stop, now
  try:
    monChan = CaChannel()
    monChan.search(monPV)
    monChan.pend_io()
    print now
  except CaChannelException, status:
    print ca.message(status)
  try:
    monChan.add_masked_array_event(ca.dbf_type_to_DBR_STS(monChan.field_type()), \
          None, ca.DBE_VALUE | ca.DBE_ALARM, eventMon)
  while not stop:
    now = strftime('\t%Y-%m-%d %X\t')
    ca.pend_event(0.5)
Best Regards,
Ritesh Sugandhi
__________ Information from ESET Smart Security, version of virus signature database 5661 (20101130) __________
The message was checked by ESET Smart Security.
http://www.eset.com
Long out record PV Monitoring error in client using CaChannel-1.5 python interface Ritesh Sugandhi
Prev: Long out record PV Monitoring error in client using CaChannel-1.5 python interface Ritesh Sugandhi
Next: How to use BOY/OPI to produce standalone simple displays Jimmy Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Long out record PV Monitoring error in client using CaChannel-1.5 python interface Wang Xiaoqiang
ANJ, 01 Dec 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
