> The big format in the bpt*.data files, as specified in section 6.17 isn't
> required? And I don't have to run the 'makeBpt' command and the stuff
> that's listed in that section?
The app dev guide says:
"Normally, it is desirable to directly create the breakpoint tables. However, sometimes it is desirable to create a breakpoint
table from a table of raw values representing equally spaced engineering units."
So my instructions are for people who directly create their breakpoint table. I've not used makeBpt but I'm sure it does a better job at slimming the table down to only what is necessary. Probably if CPU or memory is an issue, it's a good idea to create the .data files and use makeBpt.
Stephanie
> -----Original Message-----
> From: David Dudley [mailto:[email protected]]
> Sent: Thursday, December 16, 2010 7:06 PM
> To: Allison, Stephanie; EPICS tech-talk
> Subject: Re: Breakpoint Tables
> Now that's what I like. Something so simple and straightforward that even I
> can follow it.
> So....
> (Just trying to get this down to it's simplest and most straightforward
> form...)
> David
> On 12/16/10 9:14 PM, "Allison, Stephanie" <[email protected]> wrote:
> > Hi,
> > (1) Copy menuConvert.dbd from base/dbd to the app's src directory.
> > (2) In the src directory, create a breakpoint table file <bpname>.dbd. Look
> > at base/dbd/bpt*.dbd for the proper format.
> > (3) In your src/menuConvert.dbd, add a line for your new breakpoint table,
> > using the breaktable name from the first line of <bpname>.dbd. Look at the
> > existing breakpoint table entries in menuConvert.dbd for the proper format.
> > (4a) If the breakpoint table is monotonic or epics base is < 3.14.9, add
> > <bpname>.dbd to the app's dbd build in Makefile:
> > <appname>_DBD += <bpname>.dbd
> > (4b) If the breakpoint table is non-monotonic and epics base > 3.14.8, install
> > <bpname>.dbd by itself in Makefile:
> > DBD += <bpname>.dbd
> > (5) Clean/build src.
> > (6) Use the breaktable name in the record's LINR field.
> > (7) If the breakpoint table is non-monotonic and epics base > 3.14.8, change
> > st.cmd to set the non-monotonic flag and load the breakpoint table:
> > dbBptNotMonotonic=1 (rtems)
> > or
> > var dbBptNotMonotonic 1 (soft)
> > dbLoadRecords("dbd/<bpname>.dbd")
> > Stephanie Allison
> >> From: [email protected] [mailto:[email protected]] On
> >> Behalf
> >> Of David Dudley
> >> Sent: Thursday, December 16, 2010 1:59 PM
> >> To: EPICS tech-talk
> >> Subject: Breakpoint Tables
> >> I have 4 instruments that read differential pressure across V-Cone
> >> flowmeters. The
> >> manufacturer supplied us with a 10-point calibration, which covers the
> >> desired engineering
> >> range. These devices are not linear, and I think the right way to handle
> >> them is going to be
> >> to generate a breakpoint table for each (all 4 are sized differently).
> >> I'm looking through the app guide, section 6.17. Is this the accepted method
> >> to generate a
> >> breakpoint table? Since epics was installed through a package, I don't have
> >> the
> >> "menuConvert.dbd" file, so I'll have to download a source archive for that.
> >> Now, it says to
> >> copy the menuConvert.dbd file, but it doesn't tell me where to put it. In
> >> the source
> >> directory of the IOC application?
> >> Section 6.13 refers to a 'breaktable' command. Is that an easier way to do
> >> this?
> >> How about a simple step-by-step description of how to generate a breakpoint
> >> table?
> >> David
> >> "... The Crossbow Project. There's No Defense Like a Good Offense. " - Real
> >> Genius (1985)
> >> Don't think it exists? Google the Air Force X-37B project.
> David
> Genius (1985)
- RE: Breakpoint Tables Allison, Stephanie
- Re: Breakpoint Tables David Dudley
Re: building latest snapshot of streamDevice Eric Norum
Re: Breakpoint Tables Andrew Johnson
<2010>
2025
<2010>
2025
