1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Breakpoint Tables
To: [email protected]
Date: Fri, 17 Dec 2010 10:22:17 -0600
Hi David,
On Thursday 16 December 2010 21:06:06 David Dudley wrote:
> So....
> The big format in the bpt*.data files, as specified in section 6.17 isn't
> required?  And I don't have to run the 'makeBpt' command and the stuff
> that's listed in that section?
You don't have to do that if you have your own way of generating the
breaktable(name){raw, eng, ...} that the IOC can load (see 6.11, although I
suspect you have an older copy of the AppDevGuide with different numbering).
Note that you can load a .dbd file containing break-point table data using
either dbLoadDatabase or dbLoadRecords, and the table data values can be space
or comma-separated.
The makeBpt program described in 6.15 is useful if the calibration data you
have needs to be re-sampled to provide conversions with an acceptable error,
bearing in mind that the IOC code gives you values taken from a straight line
drawn between adjacent data points.  You wouldn't need to run makeBpt manually
since that's all taken care of by the build system when you tell it
	BPTS += bptXxx.dbd
and give it the data table as described in a file named bptXxx.data.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
RE: Breakpoint Tables Dalesio, Leo
Re: Breakpoint Tables David Dudley
Prev: RE: Breakpoint Tables Allison, Stephanie
Next: RE: Breakpoint Tables Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 17 Dec 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
