Hello
Your suggestion solved the problem.
Thank you for your quick response.
Janko
Hi Janko,
I hope this is a right place to ask a question about pyepics.
I think it is.
I wrote a simple program to monitor their value:
import sys
import time
from epics import PV
def callback_function(pvname=None, value=None, char_value=None,
type=None,units=None, enum_strs=None, **kw):
print "------Printout from callback ------"
fmt = ' pvname \t = %s \n value \t\t = %s \n\
char_value \t = %s \n type \t\t = %s \n\
units \t\t = %s \n enum_strs \t = %s \n'
print fmt % (pvname, value, char_value, type, units, enum_strs)
print "----------------------------------\n"
pll = PV('LUCA:ENV:ENV_SC_PLL_MONITOR')
vent = PV('LUCA:ENV:ENV_FRONT_VENT_ACT_MONITOR')
pll.add_callback(callback_function)
pll.run_callbacks()
vent.add_callback(callback_function)
vent.run_callbacks()
while True:
time.sleep(0.001)
Sorry for the trouble.
The issue is that not all of the "extra control fields" (including the
names of the enumeration states, units, and precision) have been
determined when you do PV.run_callbacks(). That is only the "native
form" of the PV
The easiest fix is to explicitly make the control fields be looked up,
either with PV.get_ctrlvars() or PV.get(as_string=True) which also
makes sure that the "char_value" is well formed. That is, I think you
want
pll.get(as_string=True)
pll.run_callbacks()
vent.get(as_string=True)
while True:
time.sleep(0.001)
Perhaps an option should be added to PV.add_callback() to make sure
the control fields are initialized. Either that, or this should be
better documented.
--Matt Newville <newville at cars.uchicago.edu> 630-252-0431
- pyepics callback function problem Janko Kolar
- Re: pyepics callback function problem Matt Newville
Re: GPIB to ethernet converter Eric Williams
Re: MOXA terminal server Eric Norum
<2011>
Test, please ignore Benjamin Franksen
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
