1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS Config for 2 Ethernet Adapters
To: "'Andrew Johnson'" <[email protected]>, <[email protected]>
Date: Tue, 15 Feb 2011 09:46:01 -0700
> Actually that variable has no effect on the IOC server, it only applies to
> the CAS which is not (yet) used by the IOC code.
The R3.15 CA server will support this functionality (in the IOC).
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Andrew Johnson
> Sent: Tuesday, February 15, 2011 9:08 AM
> To: [email protected]
> Subject: Re: EPICS Config for 2 Ethernet Adapters
> On Tuesday 15 February 2011 09:52:37 Paul Sichta wrote:
> > Look in the CA Reference Manual for your release of EPICS.  I think
> > you need to specify EPICS_CAS_INTF_ADDR_LIST .
> the
> > On Tue, Feb 15, 2011 at 10:33,  <[email protected]> wrote:
> > > I now need to take the legacy data from one network and make available
> on
> > > another network via EPICS.  I have a Linux PC with 2 ethernet
> adapters,
> > > eth0 the legacy control system, eth1 the EPICS control system.  The
> IOC
> > > runs on this machine except I cannot see the EPICS PVs via other
> machines
> > > on the eth1 network.
> > > I'm guessing that the EPICS IOC is binding to eth0 by default and
> > > expecting to serve data to this network?
> > > How do I configure EPICS to bind to eth1 rather than to eth0, is this
> > > possible?
> The IOC server binds to all the interfaces it can see; there's actually no
> way
> to change that with the current code.  I wonder whether your problem is
> actually that the machines do not have the same subnet mask settings, and
> hence their broadcast addresses are different?  On Unix systems 'ifconfig
> -a'
> will print the broadcast address; you need to make sure that all systems
> are
> using the same address.
> The output from running 'casr 1' from the IOC shell may also give some
> hints.
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it.  If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence.  -- Bertrand Russell
EPICS Config for 2 Ethernet Adapters graham.cox
Re: EPICS Config for 2 Ethernet Adapters Paul Sichta
Re: EPICS Config for 2 Ethernet Adapters Andrew Johnson
Prev: RE: soft ioc runs into fatal exception (base-3.14.12) Jeff Hill
Next: Re: EPICS Config for 2 Ethernet Adapters Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS Config for 2 Ethernet Adapters Jeff Hill
Next: Arcturus uCDimm + TFTP John Dobbins
