1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Fwd: Re: stream without asynPort]
To: EPICS <[email protected]>
Date: Mon, 21 Feb 2011 10:03:07 +0100
--- Begin Message ---
Subject: Re: stream without asynPort
To: [email protected]
Date: Mon, 21 Feb 2011 10:02:31 +0100
Hi Emmanual,
By design, a StreamDevice record needs to connect to a "bus". At the moment, I only support asynDriver as a bus system. For your application, you don't need it. Thus a "dummy" bus driver would do. I already have a "debug" bus driver that simply prints what function is called. From this is should be easy to write a "dummy" driver. I will try.
Dirk
[email protected] wrote:
Hello,
I am tryign to use a feature I have seen in stream protocols.
I would like to call iocsh function from a process variable.
ex: when a bo record is set to 1, I would like to execute 'dbl' in the iocsh.
Q: is it possible to use stream without instanciating a asynPort ?
Q: is there another SIMPLE way to do this other than with stream ?
Q: apropos is it possible in stream to pass the value of the PV in exec lines?
   ex: exec "dbpr mbboPV <valueOfMbboPV>" ;
--- End Message ---
Re: [Fwd: Re: stream without asynPort] Eric Norum
Prev: Re: USB4000 Brands Helge
Next: Epics C# Library Morozov, Petr
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: TFTP I/O Error Jim Eastman
Next: Re: [Fwd: Re: stream without asynPort] Eric Norum
