1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: TFTP I/O Error
To: "Eric Norum" <[email protected]>
Date: Mon, 21 Feb 2011 08:24:02 -0800
Eric,
These are the startup messages I received.
Welcome to rtems-4.10.0(PowerPC/Generic (classic FPU)/mvme5500) on MVME5500-0163
Now BSP_mem_size = 0x1FE00000
Marvell GT64260B (Discovery I) hostbridge detected at bus0 slot0
BSP unlisted vendor, Bus0 Slot10 DeviceID 0x263388
TUNDRA PCI-VME bridge detected at bus1 slot0
Marvell GT64260B (Discovery I) hostbridge detected at bus8 slot0
BSP unlisted vendor, Bus8 Slot10 DeviceID 0x10088086
Universe II PCI-VME bridge detected at 0x82000000, IRQ 12
Universe Master Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
0:    0x20000000 0x0E000000 0x90000000 A32, D64 [MBLT], Dat, Sup
1:    0x00000000 0x00FF0000 0x9F000000 A24, D64 [MBLT], Dat, Sup
2:    0x00000000 0x00010000 0x9FFF0000 A16, D64, Dat, Sup
Universe Slave Ports:
0:    0x90000000 0x1FE00000 0x00000000 A32, Pgm, Dat, Sup, Usr, PWEN, PREN
Overriding main IRQ line PCI info with 76
Registering /dev/console as minor 0 (==/dev/ttyS0)
***** Initializing network *****
Startup.
Attaching MVME5500 1GHz NIC1
RTEMS-mvme5500 BSP Copyright (c) 2004,2005,2008, Brookhaven National Lab., Shuchen Kate Feng
***** Initializing TFTP *****
***** Starting EPICS application *****
Can't open /TFTP/10.80.60.112/epics/mvme5500/st.cmd: I/O error
And here is what netstat 2 shows:
************ INTERFACE STATISTICS ************
***** wmG1 *****
Ethernet Address: 00:01:AF:30:50:77
Address:10.80.60.142    Broadcast Address:10.80.255.255   Net mask:255.255.0.0
Flags: Up Broadcast Running Simplex Multicast
Send queue limit:50   length:0    Dropped:0
    Ghost Interrupts:0
       Rx Interrupts:460
     Receive Packets:25
     Receive Overrun:0
     Receive  errors:0
   Rx sequence error:0
      Rx /C/ ordered:0
    Rx Length Errors:0
       Tx Interrupts:16
   Transmitt Packets:0
   Transmitt  errors:0
         Active Txqs:0
          collisions:0
          Crc Errors:0
  Link Status Change:1
***** lo0 *****
Address:127.0.0.1       Net mask:255.0.0.0
Flags: Up Loopback Running Multicast
************ MBUF STATISTICS ************
mbufs:8192    clusters: 512    free: 256
drops:   0       waits:   0  drains:   0
      free:7935          data:257         header:0           socket:0
       pcb:0           rtable:0           htable:0           atable:0
    soname:0           soopts:0           ftable:0           rights:0
    ifaddr:0          control:0          oobdata:0
Destination     Gateway/Mask/Hw    Flags     Refs     Use Expire Interface
default         10.80.60.20        UGS         1        0      0 wmG1
10.80.0.0       255.255.0.0        U           0        0      1 wmG1
10.80.60.20     00:90:7F:22:83:48  UHL         2        0   1571 wmG1
10.80.60.142    00:01:AF:30:50:77  UHL         0       10      0 lo0
71.245.107.83   10.80.60.20        UGH         1        7      0 wmG1
127.0.0.1       127.0.0.1          UH          0        0      0 lo0
************ IP Statistics ************
             total packets received          96
  packets rcvd for unreachable dest           6
 datagrams delivered to upper level          90
    total ip packets generated here          17
************ ICMP Statistics ************
              Calls to icmp_error()          10
                 ICMP panic avoided          10
************ UDP Statistics ************
                total input packets          90
                  no socket on port          10
     of above, arrived as broadcast          73
               total output packets          17
************ TCP Statistics ************
Thanks!
Jim Eastman
Sent: 18 February 2011 17:36
To: Jim Eastman
Cc: EPICS Tech Talk
Subject: Re: TFTP I/O Error
What does  'netstat 2' show?  Does it show the right network configuration?
Also, could you post more of the startup messages?  That might give a little more insight.
On Feb 18, 2011, at 4:57 PM, Jim Eastman wrote:
Hello all,
I'm trying to get an EPICS test app going on RTEMS on an MVME5500 board, and I'm encountering a problem when trying to get files from a TFTP server.
"Can't open /TFTP/10.80.60.112/epics/mvme5500/st.cmd: I/O error"
My TFTP server logs don't show any attempt at this connection.
I'm using RTEMS 4.10 and EPICS 3.14.12. I am building the apps with the -DOMIT_NFS_SUPPORT flag set in a MINGW environment on a Windows 7 machine with RTEMS-mvme5500 set as the target arch.
I am also able to download that file (and others) from the tftp server while still in the MOTLOAD prompt on the mvme board.
I have the following GEVs set on the mvme board:
mot-/dev/enet1-cipa=10.80.60.142
mot-/dev/enet1-sipa=10.80.60.112
mot-/dev/enet1-snma=255.255.0.0
mot-/dev/enet1-gipa=10.80.60.20
rtems-client-name=mvme5500
epics-script=epics/mvme5500/st.cmd
rtems-dns-server=10.80.60.12
rtems-dns-domainname=pro-dex.com
epics-ntpserver=71.245.107.83
The networking when the application loads seems to be working fine, as I'm able to get time from the NTP server.
I'm not running a BOOTP server, and so I hardcoded these network parameters into bsp_driver_config and rtems_bsdnet_config  in rtems_netconfig.c
Any assistance in this problem would be greatly appreciated. Thank you very much.
Jim Eastman
This e-mail and any attachment(s) are from Pro-Dex, Inc. and may contain information that is confidential or privileged. If you are not the intended recipient, do not read, copy or distribute the e-mail or any attachments. Instead, please notify the sender at the phone number indicated above and delete the e-mail and any attachments. Thank you.
Eric Norum
[email protected]
Re: TFTP I/O Error Eric Norum
Prev: Re: Make target_arch only ... doesn't seem to work on 3.14.11 Janet Anderson
Next: Re: Make target_arch only ... doesn't seem to work on 3.14.11 emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: TFTP I/O Error Eric Norum
Next: [Fwd: Re: stream without asynPort] Dirk Zimoch
